Each LED is tied to an if statement which is checking for different levels of humidity. As the target humidity is about to be reached, more LEDS are illuminated.
Scale:
| 1 | 10% Relative Humidity |
| 2 | 15% Relative Humidity |
| 3 | 20% Relative Humidity |
| 4 | 25% Relative Humidity |
| 5 | 30% Relative Humidity |
| 6 | 35% Relative Humidity |
| 7 | 40% Relative Humidity |
| 8 | 45% Relative Humidity |
| 9 | 50% Relative Humidity |
| 10 | 55% Relative Humidity |
Each different level in the chart shown above lights the corresponding number of LEDs on the LED bar graph.
In programming the device I used an Arduino library that can be found here: https://brainy-bits.com/blogs/tutorials/dht11-tutorial. This just makes the whole process faster and easier to read and make changes to.
All code can be found in the Details section of the project.
