So after many attempts to get the attiny88 to play ball, I think it's time to move on and use the chip I should have used all along!
Behold the power of the atmega328 and it's well trodden paths!
Apologies for the very shoddy camera work but it's running the neopixel's on its internal clock
Now I had decided that I wanted to keep to my path of keeping things super simple, so I have gone for the internal clock, thus saving myself an additional 3 components. I have also borrowed some elements from the Arduino Pro mini schematic so I can be sure that I'm doing it right!
Currently going through the old board carefully ripping up traces and adding new ones, trying to squeeze in the extra ftdi header needed for code upload duties.
Revision 3.0 is imminent...
moosepr
