Arduino based Flashlight
ATTiny controlled LED flashlight
*Atmel ATTiny85 Microprocessor based design
**Programmed from the Arduino IDE.
**Part is less than $1 in volume from Mouser
*Software/Hardware Controllable functionality
**Controllable brightness or On/Off control via analog/digital input pin
***Potentiometer can be used to control brightness level (analog)
***MicroProcessor can be used to control On/Off (5V signal level)
***Can be re-configured via software download
***Software control can allow for smoother functions like blooming on/off (digital on/off mode)
*Power Compatibility
**12V operation matches available RepRap electronics power
**12V to 5V Regulator for ATTiny85 power
*ISP Connector so the program could be downloaded on card (the ATTiny can be soldered in without a socket)
teraz wrote 11/23/2021 at 16:22 • point
nice, is possible add receiver?
for example flaslight as sender data and small camera, meybe with monocular as receiver
and pppd protocol ;D
George Gardner wrote 03/30/2018 at 08:58 • point
but why?
mr.jb wrote 07/25/2014 at 10:03 • point
