Today I worked on the printer a bit more.
Made some changes to the gcode for the print start and stop. And glued a few pices or rubber I cut from a rubber band on the bottom of the printer table to provide some grip to hold the paper in place.
See the video below. I will be updating the git hub over the next few days with some more polished code and some instructions on how to set this up with your own printer.
