This project is set up to trigger a servo every time the cloudBit receives a pulse though IFTTT’s Instagram channel. IFTTT is a service that lets you connect to different web apps through simple conditional statements. When the cloudBit is triggered, the servo pulls down on a hose connected to the nozzle of a helium tank, releasing helium into a balloon. Any time a user hashtags a name of your choosing, a trigger is sent to IFTTT, which in turn sends an output signal to the cloudBit. Bask in your glory and float on!
littleBits
Plug the servo into a power module so the servo will go to its 0% power position and hold there. Attach the swing arm (A-2) to the servo motor so the arm is pointing down toward the tilt valve. Secure the swing arm with a screw and washer. Connect the valve puller (A-1) to the swing arm (A-2) using a #4 machine screw and nut. Adjust the position of the valve puller and the board so that the hose is not touching the tube on the tilt valve (otherwise the valve may release helium even when the servo is not activated).
CiferTech
leonllrmc
Kevin Santo Cappuccio
