Any time the feeder receives a signal through the cloudBit, the servo is activated. In our case, we attached a fish food container with a small hole drilled in its side to the servo. When the servo turns, a few pellets drop out of the container and into the bowl.
You can activate the servo remotely in a couple different ways. You can either use the littleBits button in Cloud Control to send a single pulse to the cloudBit, activating the servo. Or, you could use an IFTTT channel, like Date & Time to automate the feeding at times you set.
littleBits
See the circuit diagram in the image above. Set up your cloudBit if you haven’t already. You can find information about how to do this here:
Luke J. Barker
Ian Maday
patchartrand
this reminds me of that
