I soldered an HI-Z module to test it, and after some ground issues I got it working; you can see in the video that the gain control is set to no gain, so it's acting as a voltage follower; increasing the signal gain using my Gibson SG sends the amp in saturation really easily, so I might have to modify its design. But still, the proto does its job as you can see in the video :)
