Writing the firmware will take a bit of time, writing code is not a particularly enjoyable task for me.
The next steps will be:
- Routing a PCB with a single sided load
- Routing a custom metal core PCB
- Ordering these boards from a board manufacturer
- Redesigning the button mechanism
- Adding the temperature feedback to both LED and Battery
- Overhauling the design of the whole body
- Writing a proper firmware
- Experimenting with reflow soldering the board
