To use the script on an orange pi zero, few modifications need to be made :
First use a different player : MPG123 is good
sudo apt-get install mpg123
in the script : use mpg123 instead of omxplayer :
#omxplayer $FILNAME
mpg123 $FILNAME
As the player is compatible with alsa, add a line to set the volume in the 7-9_player.sh (anywhere before starting the player) :
amixer sset 'Lineout volume control' 65%
Without the extention board, the audio output is not filtered, a RC filter might be needed.
The wifi configuration has to be set manually :
sudo nano /etc/network/interfaces
#COPY
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
#Ctrl + O
#Enter
#Ctrl + X
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
#COPY
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="WIFI_MaBox"
psk="------------------"
#Change based on your WiFi Settings
#Ctrl + O
#Enter
#Ctrl + X
sudo reboot
