The project is moving along nicely. In my infinite wisdom I put the sleds in the inner print area, have to flip them around. In real life the work area seems pretty decent, somehow larger than I envisioned. My version of the Peoples CNC Frame won't have much Z height because I want the machine to do mostly cutting and drilling and be as rigid as possible. The Z movement would be ~4-5cm. The Z mount plate could be taller, which would provide more range.
morph
