First version
A project log for Paper Pixel Display Array
A stack of standalone units that can display all combinations of 4 (2x2) pixels.
sephendevosSephenDeVos • 04/10/2017 at 06:22•0 Comments
Before the closed loop version the previous version of the display had two strips wound around a single tube (bit like a cassette tape) with a gear in the middle to drive it. I thought the tension wouldn't be much of a problem considered its a fairly short strip, but at the ends of the strip it was to tight.
