I painted BeeTee's body shortly before the cold snap made doing much of anything impossible.
I've also been working on the shoulder mounted weapons systems. This is going to be one very wide droid. I've incorporated a quick connect in the shoulders so I can easily change the loadouts or get him through doorways. You can see how it works in the video below.
