Please forgive this messy code, I was just goofing around and did not plan on sharing it, but here I am sharing it. LOL
#include <WiFi.h>
const char* ssid = "(Your WiFi Access Point Name)";
const char* password = "(Your WiFi Access Point Password)";
int ledPin = 4;
WiFiServer server(80);
#include "esp32-hal-ledc.h"
uint32_t maxint = 65535;
uint32_t servoMax = 8000;
uint32_t servoMin = 1700;
uint32_t servoLow = servoMin; //1700 + 1300;
uint32_t servoHigh = 1700 + 1000 + 1300; //servoLow+1000;
uint32_t servoCenter = (servoLow + servoHigh) / 2;
const byte numberOfServos = 12;
byte servoPins[numberOfServos] = {5, 12, 13, 14, 15, 16, 17, 18, 19, 21, 22, 23};
char command = 0;
void setupServo()
for (byte servoIndex = 0; servoIndex < numberOfServos; servoIndex++)
byte channel = servoIndex;
byte servoPin = servoPins[servoIndex];
ledcSetup(channel, 50, 16); // channel X, 50 Hz, 16-bit depth
ledcAttachPin(servoPin, channel); // GPIO servoPin on channel X
ledcWrite(channel, servoHigh); //servoMin
delay(2000);
void setup()
Serial.begin(115200);
pinMode(ledPin, OUTPUT); // set the LED pin mode
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
server.begin();
setupServo();
void Marching()
delay(500);
ledcWrite(channel, servoLow);
delay(500);
void LeftToRight(int servoValue, int dly)
for (int head = 0; head < numberOfServos; head++)
if (head >= 0 && head < numberOfServos) ledcWrite(head, servoValue);
delay(dly);
void RightToLeft(int servoValue, int dly)
for (int head = numberOfServos - 1; head >= 0 ; head--)
delay(dly);
void SpreadOut(int dly)
int half = (numberOfServos / 2);
for (int i = 0; i <= half ; i++)
int left = half - i;
int right = half + i;
if (left >= 0 && left < numberOfServos) ledcWrite(left, servoHigh);
if (right >= 0 && right < numberOfServos) ledcWrite(right, servoLow);
delay(dly);
void SpreadOutRestore(int dly)
if (left >= 0 && left < numberOfServos) ledcWrite(left, servoCenter);
if (right >= 0 && right < numberOfServos) ledcWrite(right, servoCenter);
delay(dly);
void OutIn(int dly)
int left = (numberOfServos - 1) - i;
int right = i;
delay(dly);
int value = 0;
void SendHtmlResponse(WiFiClient client)
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("<h1 style='font-size:400%;'>");
client.print("<a href='/'>Home</a><br>");
client.print("Left to Right: <a href='/A'>\\\</a> <a href='/B'>///</a><br>");
client.print("Right to Left: <a href='/C'>\\\</a> <a href='/D'>///</a><br>");
client.print("All: <a href='/E'>\\\</a> <a href='/H'>Center</a> <a href='/F'>///</a><br>");
client.print("<a href='/G'>Marching</a><br>");
client.print("<a href='/I'>SpreadOut</a> <a href='/J'>SpreadOutRestore</a><br>");
client.print("<a href='/K'>Bounce</a><br>");
client.print("</h1>");
// The HTTP response ends with another blank line:
client.println();
void ProcessRequest(String requestString)
// GET /x HTTP1.1
// 0123456789
if (requestString.length() >= 6 && requestString.startsWith("GET /") && !requestString.startsWith("GET /favicon.ico"))
command = requestString[5];
void loop() {
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
SendHtmlResponse(client);
break; // break out of the while loop:
} else { // if you got a newline, then clear currentLine:
ProcessRequest(currentLine);
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// close the connection:
client.stop();
Serial.println("client disonnected");
int dly = 100;
switch (command)
case 'A': LeftToRight(servoHigh, dly); break;
case 'B': LeftToRight(servoLow, dly); break;
case 'C': RightToLeft(servoHigh, dly); break;
case 'D': RightToLeft(servoLow, dly); break;
case 'E': LeftToRight(servoHigh, 0); break;
case 'F': LeftToRight(servoLow, 0); break;
case 'G': for (byte i = 0; i < 3; i++) Marching(); break;
case 'H': LeftToRight(servoCenter, 0); break;
case 'I': SpreadOut(dly); break;
case 'J': SpreadOutRestore(dly); break;
case 'K':
LeftToRight(servoCenter, dly);
break;
command = 0;
