Hackaday.io Hackaday.io
Sign up Log in
Smart Aquaponics System
Make your aquaponics system taking care itself
mike-loMike Lo
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.4k views
2 comments
27 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
2.4k
2
27
8
Team (2)
  • mike-loMike Lo
  • mehdibakhtiariMehdi.Bakhtiari
Join this project's team
hardware
ongoing project
automation Agriculture Farm aquaponic Internet of thing
Related lists
物联网/监控/监测
一些监测监控设备
This project was created on 07/25/2014 and last updated 2 years ago.
Description
This project start with an idea of self-managed indoor farm. To monitor and manage the system through the Internet is core of this project. This project will be monitoring the value of pH level, water temperature and light of the whole entire system.
Components
  • 1 × Arduino MKR1000 If you know how to do POST request on Particle Photon, you can use it.
  • 1 × DS18B20 Temperature sensor Make sure it come with metal case and it's water proofed.
  • 1 × pH Sensor Atlas is a good brand
  • 1 × TSL2561 Luminosity/Light Sensor
  • 1 × Grow Light you can make your own by using 5050 RGB/warm white LED
Project Logs
Collapse
  • Progress After Rebuilding the Project
    Mike Lo • 02/02/2017 at 00:34 • 0 comments
    We've make some progress on building hardware infrastructure. After we get Arduino and sensors involved we will use a home server to display it online.
    Mike Lo • 02/02/2017 at 00:33 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
meganann kilinski wrote 02/23/2015 at 16:52 • point
Hello, I am attempting to create a similar system and I'm wondering if you have more information on this project.
Mike Lo wrote 03/01/2015 at 16:20 • point
Hi Megan. I am glad to share more information with you, but I currently is changing some details in that system. What kind of information you would Ike to know
Compact kitchen thermostat, Arduino-driven with OLED display, PT100 sensor, 1.5kW heater.
Project Owner Contributor
Sousvide
alexander-urbanovichAlexander Urbanovich
Project to help beekeeper to control his hive.
Connected Beehive
chloe18lhermittechloe18.lhermitte
creative week sprint I did with my friends from 2022.08.01 until 2022.08.0x
cadquery creativeWeek helloworld
alycon47alycon47
This project uses an Arduino and some 7-segment displays to make a digital counter. This project is a good mix of hardware and software.
Digital Counter for a Coil Winding Machine
cj-windischC.J. Windisch
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Smart Aquaponics System", please tell us the reason.
Send message
Remove Member
