Here's my thinking for the frame. The obvious bit in the middle is where the panel would go. I haven't depicted mounts for the side monitors here, but that's easily done with vertical risers on each side.
A project log for Your Personal Flight Simulator
Take some off the shelf parts, some miscellaneous materials, and a couple of dead laptops and make a flight simulator
