This one is meant as "split, but monoblock" - with the MCU and two halves screwed down do a small board
untreated laminated wood: good surface grip = ideal for "literal laptop" use
another option is to keep the halves separate, for a "desktop use"
where it is beneficial to slide them around for a relaxed/straight wrist position
