• Chip Change
    gir • 01/30/2018 at 15:16 • 0 comments
    I've decided to  abandon the TDA8029 -- the driver situation for this chipset is just awful(read here)and instead use the Microchip SEC1210. A PCB is currently in the process of being fabricated (oshpark) and when it arrives, I'll be sure to report back!
  • PCBs arrived
    gir • 08/25/2017 at 20:50 • 0 comments
  • Some Images of the New Board
    gir • 05/01/2017 at 12:56 • 0 comments
    I still got some work to do - but here is a first look at the new PCB, where the OLED is not on a module, but directly soldered onto hardpass.
    Aligning the screen, so the solder pads match up, was rather tricky and took a few mintues. I used a small strip of double sided tape to hold the OLED down.
    You can see it is now much neater! The underside is a little more packed now too:
    you can see the two removed pins from the header, so the flat flex can lay underneath:
    thanks for all your support this far!
  • A new beginning
    gir • 04/17/2017 at 16:01 • 0 comments
    This is the first project log for the new and improved hardpass & hardpass-SCI.
    Since 2016, hardpass has been completely re-made in KiCad. It now uses the bare SSD1306 OLED instead of the cheap modules you usualy get. This dramatically reduces thickness - you are now only limited by the type of buttons you choose.
    Also, hardpass-SCI is now in development: it is a Smart Card Interface based on the NXP TDA8029 chip. It is intended to be used with a GnuPG smartcard.
    This means, you don't need to store your private key on the Pi's SD card, where a weak encryption key could theoretically be brute forced.
    I have begun using a GnuPG smartcard on my Laptop, and it is relatively easy to set up. Same as last year, my highest priority is University, so development might be a little slow.
    I'd like to hear from you if you want to contribute to either hardpass or hardpass-SCI - just message me here or on github!
