Hacking a Cheap Wifi Outlet
Others have shown cheap Chinese WiFi Outlets can be hacked. Time to see how hard it is. (Hint: not very)
Inspired by this project: https://hackaday.io/project/20316-wifi-outlet-hacking I found a $AU20 WiFi outlet with an Australian plug, hoping it had an ESP8266 built in. It did. And I managed to install my own firmware, connecting it to my Home Assistant setup via MQTT.
DISCLAIMER: This project plugs in to the mains, which has dangerous voltages and can kill you. Never plug in the device working on this project - you can re-program using an external 5V supply.
I have a Rancilio Silvia coffee machine, that needs time to warm up correctly in the morning - 30 minutes gets everything up to temperature, allowing me to draw excellent coffee shots.
For the past couple of years, I run a simple mechanical timer that turns on at 6am, and goes off at 8am which is fine for the days I go to work, but if I work from home, or it's the weekend, I'm left with a cold coffee machine unless I turn it to manual mode - which often results in me forgetting to turn it off!
To get around this, I'd been planning on getting a smart switch which would integrate with my Home Assistant setup. I looked at the Belkin Wemo, but it seems a little expensive at $80 a pop.
I thought about designing and building my own one, but the prospect of messing around with mains power didn't excite me, nor did 3D-printing a case - 3D printing plastic, by definition isn't very fire resistant.
Browsing Hackaday.io, I stumbled across this project, and it got me wondering if I could find an ESP8266-based Australian WiFi outlet. After a bit of googling, I found something that at least looked the same for $AU20 delivered. Even if it wasn't ESP8266, I could probably gut it and insert a custom board, so I ordered one.
It arrived pretty quickly.
I promptly pulled it apart. There was a daughter board that looked suspiciously like a ESP8266 although the footprint wasn't the same as any reference design I could find.
So, I pulled the little metal shield off, and low-and-behold! An ESP8266! Now that I knew we were in business, I installed the iPhone application that comes with it, to try and work out how it was wired up.
The device
This particular switch has an obnoxious blue LED that is used to indicate power, and network connection (it flashes when not connected). It also has a red LED that is on when the relay is turned on. Finally, there is a button that allows you to turn the relay on and off manually.
Pins
A quick google, and I found the pin out of the ESP8266 chip - now it was just a matter of tracing the wiring back to each LED and the switch. I also needed to find where the TX, RX, Reset and GPIO0 were so I could program it.
Here is what I found:
  • GPIO 4 is the Blue LED
  • GPIO 5 is both the Red LED and the Relay
  • GPIO 13 is the button
I've marked the TX, RX, Reset and GPIO0 pins on the above image. By wiring these pins up to a FTDI cable, I was able to reprogram the switch, thus freeing me from the shackles of the crappy iOS app, and allowing my home-assistant.io server to talk to the switch.
Now, thanks to a Home Assistant and a NodeRed flow, the coffee machine will turn on between 6:30am and 1pm everyday UNLESS it detects that I'm not home. Nice!
You can see the code that I use (It's based heavily on my garage door opener project).
  • 1
    Step 1
    Remove the four screws on the back of the plug
  • 2
    Step 2
    Remove the two smaller screws on the back of the PCB that is attached to the front of the plug
  • 3
    Step 3
    Solder some fly wires to Pins 3 (GPIO 0) and 12 (Reset) of the ESP8266 daughter board. Solder wires to the TX and RX pads on on conn 2.
    Remember that if GPIO 0 is held low on a reboot (ie reset is triggered by pulling the RESET pin low), the device is in programming mode.
View all 5 instructions
