I decided to make a few more modifications to the board. I wanted to simplify component placement so I switched some of the single resistors over to resistor arrays, specifically on the LEDs. I also decided to drive the LED's properly by using MOSFET switches instead of directly from IO pins.
I still need to update my pin out diagram and modify the pin assignment in the software, but that can wait until I actually spin a few of these for testing.
