USBlib in Arduino and Energia IDE
A project log for Roadrunner (the Arduino-Tiva)
An Arduino clone based on a TI's Tiva TM4C123G (An 80Mhz ARM M4F with USB OTG)
jacobJacob • 06/07/2017 at 22:32•0 Comments
After spending a long ninght working through the Arduino IDE compile options, I was able to add support for TI's USBlib, which is used as part of the boot loader trigger. I decided to emulate he Arduino Loenardo boot loader process. This board appears as a USB VCOM port and connecting to it at 1200 baud causes it to switch into USB DFU mode.
Once I get DFU flashing working from the IDE's I'll post an update to the board package and corresponding json index file.
