Hackaday.io Hackaday.io
Sign up Log in
Enhanced IOT Light Switch
Particle Photon + PIR Motion Sensor + Temperature Sensor
= Enhanced IOT Light Switch
eric-moyerEric Moyer
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
552 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
  • The 2017 Hackaday Prize
View Gallery
872
0
552
8
Team (1)
  • eric-moyerEric Moyer
Join this project's team
  • Enhanced IOT Light Switch Project Code
  • Sparkfun TLS2561 Luminosity Sensor Exampl
  • Sparkfun TLS2561 Luminosity Sensor Librar
  • Adafruit TLS2561 Luminosity Sensor Librar
  • Adafruit Sensor Library (need with the ab
hardware
ongoing project
2017HackadayPrize Particle Photon iot motion light switch
Related lists
2017 THP: Digi-Key Parts
Hackaday Prize Entries using Digi-Key parts
This project is submitted for
  • Design your concept
  • Best Product
This project was created on 04/19/2017 and last updated 10 years ago.
Description
You have at least one light switch in every room of your house however we have only been using these fixtures to turn on/off the lights. Even "smart" light switches haven't expanded the role your light switch can have in the overall function of your home. This project will expand the functionality of you light switch and make it truly "smart".
First, lights switches have already been ideally placed in your home since they provide a key function (turn on/off the light(s)) and thus are typicaly at the entrance to every room and all high traffic areas. They also provide a power source for any additional electronics that need to be added to the system so you don't have to worry about a perfectly placed outlet.
The heart of this new system will be a Particle Photon development board which provides instant cloud interface using Particle.io or IFTTT.
Files
Enhanced IOT Light Switch.pdf
Information flow for each component of the enhanced lights switch.
Adobe Portable Document Format - 1.46 MB - 04/19/2017 at 23:36
Preview
Project Logs
Collapse
  • 4/19/2017: Additional Project Information
    Eric Moyer • 04/19/2017 at 23:50 • 0 comments
    I posted a .pdf file that covers how I expect information to flow between all the components of the project.
    Here is an example:
    Thank you again to everyone who is following this project. Don't forget to "like" it.
  • 4/19/2017: Project Kick Off
    Eric Moyer • 04/19/2017 at 08:24 • 0 comments
    Thank you for taking the time to look at my project. Please don't forget to "like" the project since there is still a few $$ of funding available.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Enhanced IOT Light Switch", please tell us the reason.
Send message
Remove Member
