History and Background
During my studies in medical informatics i got fascinated in everything that involves hardware and software. The first project that i wanted to tackle was a RGB Led Cube. This was around the year 2006. At that time was around but not very well known and Microcontroller programming was not as accessible as today. Especially 32Bit Microcontroller were hardly accessible in case you were not a professional.
Anyway i decided to built one of these cubes and wanted an RGB Led Cube of Size 5x5x5 with a spacing of 5cm in between the LEDs to get quite a visual effect and a Cube that was not too small.
Software
Although is was already programming since multiple years i never did a project like this. I was especially inexperienced in Hardware so i decided to develop a Client application for the Cube first.
That client Software is QT-based (i can't say anymore why i choose QT, but it was a wise decision), and has an OpenGL Renderer that shows the Cube in 3D. The Size of the Cube can be changed using Configuration, so it can also be used for bigger or smaller Cubes.
The idea is that you can create 3D movies or 3D Pictures by editing the cube in the 3D viewer. You can safe and load these 3D Pictures and Videos from File. The Software also includes algorithms that can be played in the viewer.
Hardware design
When i was started to work on the Cube i was a student and wanted it to be cheap. I wanted to use components that i could get everywhere and that are cheap. Also i wanted to learn hardware design and soldering so i decided to go for a solution with an easy to use AVR and discrete Hardware. I already owned a Pollin AVR Net IO Board (AVR NetIO) , which i decided to use. The board is basically a large AVR with an Enc28j60 for Ethernet and some connectors to access the GPIO.
So i decided to use the Ethernetport of the AVR NetIO to receive the commands from the Client Software so i could not only simulate the Cube in the Software but also play whatever the Software shown (Pictures, Videos, Algorithms) on the Cube in realtime.
Going further with the Design i found out that Common cathode LEDs were cheap at that time so i bought a bunch of them (i needed 125) and started my design around the Atmega644P that i put onto the NetIO and the Common cathode LEDs.
As usual the LEDs are controlled using multiplexing. So i needed 5 Pins for the Cathodes and 75 Pins (25 for each color) for the Anodes. I needed to use any kind of port expansion and again i wanted easy to get hardware and broaden my software development skills. So i used Atmega48P AVRs as port expanders that are connected to the NetIO via I2C. Per Layer of Cube i used an AVR so that the idea of the modularity was born. I could simply add new AVRs to the I2C Bus if i ever decided to build a bigger cube.
More design considerations
I wanted the Cube to be really bright and multiplexing takes away brightness so i am driving the LEDs with 60mA at 5V which can result in a consumption of 5V*75*60mA = 22.5W (as in multiplexing only 25*3 LEDs can be switched on at a time). In order to be safe i decided to use FETs for controlling the Cathodes. The Anodes are controller by discrete transistors that are connected to the micro controller via a resistor and to the LED via dropping resistor.
For the Full Cube this sums up to more than 150 resistors and more than 80 transistors. (i would never do this again and use a darlington instead. However you can go out to every electronics store and buy the BC327 that i used.....)
Arduino and Raspberry age
I was working on the initial design of the cube for multiple years. It was a big project. (Especially the software was big). At some time i realized that the Code for generating 15 channels of Soft-PWM did not fit into the ROM of the Atmega48P so i dropped that idea and simply used the Atmega48P as port expanders as stated above and reduced the number of colors to 7. Additionally at that time i decided to use Arduino for convenience. (Unfortunately the Bootloader does not fit into the ROM as well so that the compiled hex file needs to be loaded without the boot loader).
With the rise of the Raspberry i also dropped the idea of using the Ethernetport of the NetIO. Instead i connect a Raspberry Pi via serial port to the project (You see. It is not so cheap anymore if you do this. But it gets fancy now!).
By modifying the QT application could get it to work on the raspberry (remove OpenGL and QT). It was not so useful anymore. I then added a TCP Server and a TCP Client to the application and mounted a Wifi adapter to the raspberry.
This allows to run the application both on the computer and on the raspberry. The raspberry application on the raspberry can accept packages on TCP and send them to the NetIO board via serial.
I had a cube that i could control wirelessly using a rich desktop application. That was amazing
Adding a WebUI and a Plugin Framework
I was not yet completely satisfied. I wanted to control the Cube from my couch using my Phone. I found out that someone wrote a C++ based web server for QT (Tufao), which i added to application. That web server serves a jQueryUI based GUI from which i can control most of the Cubes parameters using a web browser (e.g. mobile phone). So now i was able to use both, the rich client application, or a smaller web based application.
I thought i was mostly finished by then and started to develop algorithms for the cube. This was truly unsatisfying as after each change on the algorithm i had to recompile everything. So i developed an interface for algorithms and leveraged Qt's plugin mechanisms, so that i can built algorithms as shared object libraries without recompiling the whole application. This is nice. Now i can simply upload a new algorithm to the cube via ssh without recompiling anything.
Where to go from here
This is the story of my cube until the year of 2017. I revisited the cube and the quality is... lets say improvable... This is quite natural. I was inexperienced, in the middle of the learning process and worked iteratively with the only goal of getting things done quickly. There is a lack of design and documentation.
Anyway. during my project on Hackaday i will revisit the code and at least add documentation and discuss drawbacks. In this scope i will release both the embedded as well as the QT - based software under GPL or LPGL license on my github repository.
To allow readers to rebuilt the project i will discuss how the cube can be built, i will redraw wiring diagrams and i will document the system architecture in its' current state.
Additionally i will show how plugins and algorithms are written. Something that is on my list is a plugin to visualize the state of my OpenHAB based home automation on the cube.
Community project
The basics are done. Let's use that architecture and improve it. It is rich and packaged of features but both software and Hardware need some love to be cleaned up. The plugin framework is a nice starting point to share algorithms and to built a community around cube developers.
Things to do
- Create wiring diagram
- Add components list
- Create component diagram
- Document and upload embedded code
- Document and upload QT-based code
- Write some more beautiful algorithms
