The 3-D model for the standalone light is complete and as I did with the model for the glasses, I have created a GIF for your viewing/ analyzing pleasure. The primary job of the case is to hide the electrical wiring of the light and keep the user safe (seeing as how it is running on 3A). When designing the case, I made little tunnels within it so that the wires are not exposed, there is a rectangular hole towards the end of the case and that houses the actual 4 LED lights, below those is an even bigger rectangle which houses the ESP running the lights and the network. At the bottom of the case, there are two circular holes that will be the pathways for the cathode and anode wire from the wall outlet. Much like the way the current standalone light has the LEDs on the back of the adapter, the case will be mounted to the back of the adapter and hold the ESP in place and hide the wiring. A piece of the casing goes between the wall adapter and the wall in order to hold the back plate in place. I will provide a fully rendered version of this most likely tomorrow (5/13/17). The .STP files will also be posted after all the models are rendered.
Adellar Irankunda
