Just released Visuino version 7_8_3_20
- Added Quaternions support
- Added Complex To Analog and Quaternion To Analog components
- Improved Signal Generator design
- Added SHT20 Temperature Humidity component
- Added Arduino Sleep modes
- Improved Shift Register support
- Improved M5 Stack Stick C support
- Improved Grove System support
- Improved NeoPixels support
- Improved GPS/NavSpark support
- Improved DHT12 I2C component
- Improved Time Setting elements
- Added ESP32 Light Sleep element
- Added M5Stack Laser Ranging Grove Unit VL53L0X component
- Added M5Stack Stick C Yun Hat
- Added M5Stack Stick C ADC ADS1100 Hat
- Added M5Stack Stick C DAC MCP4725 Hat
- Added M5Stack Stick C Infrared Thermometer MLX90614 Hat
- Added M5Stack Stick C Ranging VL53L0X Hat
- Added M5Stack Extended IO PCA9554 Unit component
- Added M5Stack Serial GPS Unit component
- Added M5Stack DAC Unit MCP4725
- Added Infrared Temperature Sensor Unit MLX90614
- Added M5Stack ADC Unit ADS1100
- Added M5Stack Accelerometer Unit ADXL345 component
- Added M5Stack Color Sensor RGB Unit TCS3472 component
- Added M5Stack Mini Relay Unit
- Added M5Stack Mini Button Unit
- Added M5Stack Keyboard Unit
- Added M5Stack Makey Capacitive Touch Unit
- Added Texas Instruments TCA9548A I2C Switch component
- Added M5Stack I2C Expansion Unit TCA9548A component
- Added M5Stack RGB LED Unit component
- Added M5Stack HEX RGB LED Board component
Updated version of the User Code Component , and Experimental Sub Design support are included in Visuino Pro available in the MeWe Community for you to download
