Just released Visuino and Visuino Pro version 8_0_0_31
- Improved IDE Speed and user interface
- Added Adafruit Airlift Nina ESP32 Module
- Added Adafruit AirLift Shield ESP32 WiFi
- Added Adafruit AirLift Feather Wing ESP32 WiFi
- Added Adafruit AirLift Itsy Bitsy ESP32 WiFi shield
- Added Adafruit Feather 328P
- Added Adafruit Feather RF52
- Added Adafruit Metro M4 Express
- Added Adafruit Metro M4 Express AirLift WiFi
- Added Adafruit Metro M4 Grand Central
- Improved Feather Wings support
- Added Arduino MKR1010 WiFi support
- Added Arduino Nano 33 IoT support
- Added QMC5883/GY-271 Compass component
- Improved HMC5883/GY-273 Compass component
- Added Array Snapshot components
- Added Remember Array components
- Added Compare Byte Value component
- Added Byte Multi Merger component
- Added Seeeduino Lotus Grove board
- Added Seeeduino Lotus Grove composite KIT as board
- Added Seeed Studio RP2040 XIAO support
- Improved Raspberry Pi RP2040 Pico support
- Added Orientation 3D support
- Added large number of Orientation 2D and Orientation 3D components
- Added On Disable functionality for all generators that can use it
- Added support for a number of direct pin modules
- Added LSM6DS3 Accelerometer/Gyroscope I2C and SPI components
- Improved Grove support
- Added Seeeduino DHT11 Grove module
- Added Seeeduino OLED SSD1315 Display Grove module
- Added Seeeduino LIS3DH Accelerometer Grove module
- Added Seeeduino Grove Buzzer module
- Added Seeeduino Grove LED module
- Added Seeeduino BMP280 Air Pressure module
- Added Seeeduino Grove Light Sensor module
- Added Seeeduino Grove Microphone module
- Added Seeeduino Grove Potentiometer module
- Added Complex Array filters
- Added Laser component
- Added Get Host IP operation
- Added ESP32 WiFi Low Power mode support
- Improved BNO55 Accelerometer/Gyroscope support
- Improved ESP8266 Generic implementation
- Reduced memory usage
- Added more board specific icons
- Improved recovery of some damaged Visuino files
- Improved error reporting in the IDE
- Number of bug fixes in the IDE
