Just released Visuino and Visuino Pro version 8_0_0_37
- Improved IDE Speed and user interface
- The generated code in many cases uses Less RAM
- Expanded Image Data support
- Added Fingerprint Reader support
- Added MCP9808 I2C Thermometer component
- Added TTP226 Touchpad component
- Added TTP229 Touchpad components(Serial and I2C)
- Added DS3502 Digital I2C Potentiometer component
- Added SGP30 I2C Air Quality Sensor component
- Expanded and improved JSON support
- Added Image to Binary and Binary to Image converters
- Added Digital To Binary component
- Added Extract Image Info component
- Added Array Memory elements
- Added initial 64 bit integer/Unsigned support
- Added more Array type components
- Added Binary data Insert/Remove/Replace element components
- Added Binary Snapshot component
- Added Binary Multi Source component
- Added Remember Binary Data(Array) component
- Added Binary On/Off and Toggle Switch components
- Added Binary Demux components
- Added Binary Mux components
- Added Analog Array To Binary and Complex Array To Binary components
- Added Array Replace components
- Improved ESP8266 and ESP32 SSL support
- Added ESP8266 Network Time support
- Improved AirLift WiFi support
- Added Flash and EEPROM support for binary data
- Improved Internet Time support
- Added support for Millisecongs Unix Time
- Added Absolute Humidity component
- Added Elegoo SmartCar V4 WiFi shield
- Updated Packet/Unpacket implementation
- Improved Remember implementation
- Added ESP32 WiFi Transmit Power setting
- Added ESP8266 WiFi Transmit Power, and Physical Mode settings
- Added 3D Value component
- Added Daylight Offset to Internet and Network Time
- Improved Sub Diagrams support
