Just released Visuino 7_8_2_226
https://www.visuino.com
Significantly reduced memory usage by the generated code ( Up to 80% less memory usage! )
Added ESP32 Servo support
Added support for I2C address scramblers
Added support for Heltec ESP32 LoRa WiFi OLED Modules
Added ESP32 I2C and SPI pin mapping
Added ESP8266 I2C pin mapping
Improved TCN75A support
Added support for recording and playing RGBW Color file elements in the microSD
Improved LCD fields support
Improved LCD Custom Symbols support
Added Replace String component
Added Replace Analog Array component
Added new experimental user code component in the Visuino Pro version available in the G+ Community
https://plus.google.com/communities/116125623808250792822
Updated version of the Visuino Component Development SDK is also available in the G+ Community and the Facebook Beta group: https://plus.google.com/communities/116125623808250792822
http://www.visuino.com/download
