Just released Visuino 7_8_2_228
https://www.visuino.com
- Added EEPROM support
- Added ZS-042 RTC DS3231 + EEPROM module support
- Redesigned Graphics support to use significantly less memory
- Reduced memory usage by a number of SPI components
- Expanded support for GPIO modules
- Improved ESP32 support
- Improved SD cards support
- Improved IS31FL3731 display support
- Improved Packet support
Added new experimental user code component in the Visuino Pro version available in the G+ Community
https://plus.google.com/communities/116125623808250792822
Updated version of the Visuino Component Development SDK is also available in the G+ Community and the Facebook Beta group:https://plus.google.com/communities/116125623808250792822
http://www.visuino.com/download
