Just released Visuino version 7_8_3_3
- Brand new revolutionary code generation design producing extremely efficient low Flash/ROM and especially RAM usage - up to 90% less RAM usage by the generated code, and up to 60 % less Flash/ROM usage
- Up to 90% execution speed improvement by the generated code
- A Completely Free Mode of Visuino now available for entry level users and students
- Added support for the M5 Stack Basic Core module
- Added initial support for the PLDuino PLC WiFi Module
- Significantly Improved RemoteXY mobile device remote support
- Improved Controllino PLC RS485 support
- Reduced memory usage by some of the components
- Improved ESP8266 and ESP32 SSL sockets
- Some IDE stability improvements
Updated version of the User Code Component , and Experimental Sub Design support are included in Visuino Pro available in the MeWe Community for you to download
