Just released Visuino version 7_8_3_43
VISUINO PRO IS NOW OFFICIALLY RELEASED!
- Added initial CANbus support
- Added MCP2515 support
- Added Text Parser/Splitter component
- Improved ESP32 support
- Improved Controllino RS485 support
- Added TTGO-T4 ESP32 (V1.3) support
- Added ESP8266-01 Shields support
- Added ESP8266-01 Simple Relay Shield
- Added ESP8266-01 LC Technology Serial Relay Shield
- Added ESP8266-01 LC Technology 2 Relays Shield
- Added ESP8266-01 LC Technology 4 Relays Shield
- Added TTGO-T18 ESP32 (V1.0) support
- Added MPU6886 Accelerometer Gyroscope component
- Added M5Stack ATOM Lite support
- Added M5Stack ATOM Matrix support
- Added M5Stack StickC new version support
- Added BeginText, EndText, SeparatorText, and ElementPrefix properties for the Binary To Text component
- Improved Nextion Display Multi Page support
- Added the option to use ###strong#< without index for the Formatted Text
- Added M5Stack Laser Transmitter Unit
- Added M5Stack Optocoupler Unit
- Added M5Stack Photoresistor Unit
- Added M5Stack EarthMoisture Unit
- Added M5Stack StickC Card Keyboard Hat
- Fixed bug in the Inverse component
- Improved RemoteXY support
- Added Most Significant First property to the Make, and Split Structure components
- Added Timeout Timer component
- Added Electricity Meter EMH Metering ED300L Serial component
- Added ILI9341 Display Inverted property
- Added SPISpeed property to multiple SPI components
- Improved Formatted Text component significantly reducing memory usage and improving speed
- Improved Flash storage support
- Improved Infrared Remote support
- Improved M5Stack StickC JoyC Hat support
- Improved Macetech RBM Shades support
- Improved Clock Modified component
- Improved MicroSD card support
- Improved Arduino Micro Pro support
- Improved ESP8266-01 support
- Improved IDE stability
