Just released Visuino and Visuino Pro version 8_0_0_89
![](https://cdn.hackaday.io/images/3774921688264576250.png)
- Huge user interface improvements over the entire IDE
- Added option to display the Component Toolbar as Tree View
- Added advanced search in the Visuino Design view allowing to search for components, properties and elements
- Improved search in the generated code view
- Updated to use the latest Arduino-CLI
- Added initial support for OTA Upload to the Visuino IDE
- Added search option for all terminal windows
- Added search option for the CustomCode component
- Added Raspberry Pi RP2040 Pico W WiFi support
- Improved Component Toolbar with option to specify the name when adding components from it
- Improved Element Editors with option to specify the name when adding elements
- Improved Properties Inspector with added support for property icons
- Added Audio support, and initial set of components
- Added ESP I2S, and PDM support
- Improved support for MAC and IP Address bindings
- Redesigned Interrupt support
- Added Base64 encode/decode components
- Reduced memory usage by the generated code
- Improved *.vcomp files support
- Added Interpolate Analog component
- Step/Iterate Complex Array Items component
- Get Complex Array Item At Index component
- More components and classes moved to *.vcomp implementation, and made open source
- Added Binary Insert In Items component
- Added Step/Iterate Binary Items component
- Added Get Binary Item At Index component
- Added Split Binary Bytes component
- Added Min and Max reached pins to the Counters and Rotary Encoder components
- Improved Arduino Nano 33 IOT implementation
- Improved BBC Micro:Bit, Raspberry Pi, and Arduino 101 implementation
- Improved ESP Now support
- Added ESP32 Wired Ethernet support
- Added ESP32 WPA2 Enterprise WiFi support
- Added M5 Stack Core 2 support
- Added support for SensOper SC-EN-I6-TO4-E, and SC-SE-I8-AM6-TO2 ESP32 PLC Controllers
- Added Keyboard and Mouse modules for the STM32 boards
- Added WT32-ETH01 Ethernet (ESP32) board support
- Added Split Text To Chars component
- Added Text TCP/IP IPv4 Address To Unsigned component
- Added Unsigned TCP/IP IPv4 Address To Text component
- Added Split Unsigned TCP/IP IPv4 Address To Octets component
- Added Merge Octets To Unsigned TCP/IP IPv4 Address component
- Added Merge Octets To Text TCP/IP IPv4 Address component
- Improved Ethernet Shield implementation
- Added Triangle, Sine, and Square Complex Generator components
- Added Shenzhen Yongfukang Technology I2S Mono Audio Amplifier (Speaker) NS4168 support
- Added Knowles I2S Mono Audio Microphone – SPH0645LM4H support
- Added Knowles PDM Mono Audio Microphone – SPM1423HM4H support
- Added M5Stack Ultrasonic Ranger(Ping) Unit component
- Added 2D Distance component
- Added Accumulate(Integral) Complex component
- Added Maxim Integrated I2S Mono Audio Amplifier (Speaker) MAX98357A/MAX98357B support
- Added Maxim MAX31865 RTD PT100/PT1000 Resistance Thermometer(SPI) support
- Added Radio Time DCF77 support
- Added Texas Instruments ADC ADS1113 (I2C), and Texas Instruments ADC ADS1114 (I2C) support
- Added support for changing Teensy 3.X PWM Resolution and Frequency
- Added a large number of other components
- Improved Texas Instruments ADC ADS1015 Auto Scan (I2C) support
- Improved MAX31855 Thermocouple Amplifier support
- Added multitouch support
- Added more array manipulation components
- Added Complex Change Only component
- Improved Raspberry Pi RP2040 support
- Improved Digispark support
- Improved Seeed Studio Wio Terminal support
- Improved IDE performance
- Expanded RemoteXY Support
- Improved Binary To Text converter
- Improved Text To Char converter
- Improved Pressure To Altitude component
- Improved Old Visuino versions updater
- Improved overall user interface
- Improved Sub Diagrams support
- Added Copy and Paste for component elements
- Added automatic substitution for more elements when replacing components
- Improved Replace for Structure and Packet components, allowing you to change from Structure to Packet and Make Split while preserving all the channels
- Improved Packet Unpacket implementation
- Improved Boards and Libraries management
- Improved code generation
- Improved Installer
The Visuino Pro and the Visuino SDK are available on the Download page:
https://www.visuino.com/download
Please enjoy!
