Just released Visuino and Visuino Pro version 8_0_0_165
- Added DC Motor Driver (TB67H450FNG) support
- DFRobot Fermion: 1.8″ Display + MicroSD Module
- Added eMakeFun Maker-ESP32 support
- Added ESP-Drone ESP32-S2 support
- Added FireBeetle 2 ESP32 C6 support
- Added FireBeetle 2 Shields support
- Added LCD Wiki ESP32 E32R28T Touch Display support
- Added MCP2517 and MCP2518 CAN FD modules support
- Added Keyestudio ESP32 Plus Board support
- Added Passive Infrared Motion Sensor (PIR) component
- Added Microchip MCP3004 4 Channels ADC (SPI) support
- Added Microchip MCP3008 8 Channels ADC (SPI) support
- Added MicroSD Format and Erase
- Added MicroSD Total, Free and Used Size information
- Added Nano AtMega328P V3.0 0.42″ OLED Supermini support
- Added Seeed XIAO ESP32 C6 support
- Added Semtech SX1507 GPIO with LED Driver (I2C) support
- Added Semtech SX1508 GPIO with LED Driver and Keypad Engine (I2C) support
- Added Semtech SX1509 GPIO with LED Driver and Keypad Engine (I2C) support
- Added Waveshare Display Breakout support
- Added Waveshare ESP32-H2-Zero support
- Added Resistance Soil Moisture Sensor component
- Added DC Motor Driver 2 PWM Pins Bridge (HR1124S) component
- Added Plantower Particle/Dust Sensor PMS1003/PMS5003/PMS7003/PMSA003A component
- Added XPT Touch XPT2046 support
- Improved Custom Code component Arduino Code import
- Improved Canaduino PLC 500-24 support
- Improved DateTime compare visual bindings support
- Improved DHT11 ESP8266-01 Shield support
- Improved ESP32 HiGrow, and DIY More ESP32 HiGrow support
- Improved FireBeetle 2 ESP32 S3 support
- Improved Funduino Joystick Shield support
- Improved Generic RP2350B Board support
- Improved MMC MicroSD support
- Improved MQ135 Gas Sensor support
- Improved Raspberry Pi Pico (RP2040) support
- Improved Seeeduino Lotus Grove support
- Improved SensOper “SC-EN-I6-TO4-E ESP32” support
- Improved TexasInstruments INA226 support
- Improved TinyLab support
- Improved TTGO T-Deck ESP32 S3 MicroSD support
- Improved M5Stack CoreS3 Touch support
- Improved M5Stack Dial – ESP32-S3 Smart Rotary Knob touch screen support
- Improved Metro Grand Central M4 Express support
- Improved TFT Parallel Display Shield touch support
- Improved MCP2515 support
- Added buttons support for the TFT Color Touch Screen Display ILI9341 Shield Improved ESP32 support
- Added “Add Analog Array Value” component
- Added “Subtract Analog Array Value” component
- Added “Subtract From Analog Array Value” component
- Added “Divide Analog Array Value” component
- Added “Divide Analog Array By Value” component
- Added “Normalize Analog Array” component
- Added “Square Analog Array” component
- Added “Raise To Power Analog Array” component
- Added “Square Root Analog Array” component
- Added “Absolute Analog Array Value” component
- Added “Inverse Analog Array (Change Sign)” component
- Added “Map Range Analog Array” component
- Added “Dead Zone Analog Array” component
- Added “Dead Zone Scaled Analog Array (Map)” component
- Added “Analog Array Natural Logarithm” component
- Added “Analog Array Binary (Base-2) Logarithm” component
- Added “Analog Array Common (Base-10) Logarithm” component
- Added “Min Limit Analog Array” component
- Added “Max Limit Analog Array” component
- Added “Limit Analog Array between Min and Max” component
- Added “Analog Array Sine of angle (Radians)” component
- Added “Analog Array Cosine of angle (Radians)” component
- Added “Analog Array Radians to Degrees” component
- Added “Analog Array Degrees to Radians” component
- Added “Add Complex Array Value” component
- Added “Subtract Complex Array Value” component
- Added “Subtract From Complex Array Value” component
- Added “Divide Complex Array Complex Value” component
- Added “Divide Complex Array By Complex Value” component
- Added “Divide Complex Array By Analog Value” component
- Added “Multiply Complex Array By Complex Value” component
- Added “Conjugate Complex Array” component
- Added “Multiply Complex Array By Analog Value” component
- Added “Divide Complex Array Analog Value” component
- Added “Add Integer Array Value” component
- Added “Subtract Integer Array Value” component
- Added “Subtract From Integer Array Value” component
- Added “Divide Integer Array Value” component
- Added “Divide Integer Array By Value” component
- Added “Multiply Integer Array By Value” component
- Added “Absolute Integer Array Value” component
- Added “Inverse Integer Array (Change Sign)” component
- Added “Limit Integer Array between Min and Max” component
- Added “Min Limit Integer Array” component
- Added “Max Limit Integer Array” component
- Added “Add Unsigned Array Value” component
- Added “Subtract Unsigned Array Value” component
- Added “Subtract From Unsigned Array Value” component
- Added “Divide Unsigned Array Value” component
- Added “Divide Unsigned Array By Value” component
- Added “Multiply Unsigned Array By Value” component
- Added “Limit Unsigned Array between Min and Max” component
- Added “Min Limit Unsigned Array” component
- Added “Max Limit Unsigned Array” component
- Added ESP32-C3 Super Mini Plus support
- Added Waveshare ESP32-S3 ETH Camera support
- Added Freenove ESP32-S3 Camera support
- Added RGB/BGR option for the ILI9341 Display component and shield
- Improved Arduino UNO R4 Minima support
- Improved Arduino UNO R4 WiFi support
- Improved Arduino UNO Q support
- Improved Arduino Nano R4 support
- Improved “SensOper “SC-EN-I6-TO4-E ESP32” support
- Improved TSCINBUNY ESP32 Plus Board with Camera support
- Improved CAN FD support
- Improved STM32 boards support
- Improved DHT11, DHT21, DHT22, AM2301 support
- Improved Texas Instruments INA226 support
- Improved Keypad implementation reducing memory usage
- Modified to use SdFat
- Added ESP32 Serial Invert, and Receive/Transmit Queue config support
- Detect New Port – Automatically detects a newly connected port as soon as it appears.
- Improved SPI transfer performance
- Windows Notifications – Generates Windows notifications when Visuino is running in the background or is not the active application, for example, notifying you when compilation is finished.
- The IDE splitters are made easier to see
- Added option to send binary in the terminal
- Improved IDE performance
- Improved IDE gesture support
- Improved IDE object inspector preserving the state when switching between components
