Added Sending E-Mail SMTP components
Added ESP8266 SSL Support
Added support for Interrupt driven Humidity and Thermometer DHT11/21/22/AM2301
Added optional period to the Repeat Clock component
Improved EEPROM support
Improved Sequence component
Improved Value Array component
Improved Controllino Maxi Automation support
Reduced memory usage by some of the components
There is also updated version of the Visuino Pro with improved Modbus support available in the G+ Community:
https://plus.google.com/communities/116125623808250792822
Updated version of the Visuino Component Development SDK is also available in the G+ Community and the Facebook Beta group:
