Lights ON!
A project log for Obsolete Time
Minimalist desk clock based around Russian Nixie tubes.
operaptoropeRaptor • 10/08/2014 at 00:20•0 Comments
Boards are populated and after some debugging and adjustments (cold solder joint oops) it lights up!
It is great to see the driver board fit nicely in the case. For now the controller board is sitting outside for convenience but will be moved inside after the software debugging is finished.
More updates updates and good pictures very soon.
