I did changes to my control program to log the accelerometer data before a move and while moving the robot. This way I can see the difference between the values of standing still and moving.
Later I will add code to check if the robot does move if it sends the commands to the motor driver.
So the robot can recognize if it is stuck somewhere and can't move forward.
jay-t
