Gearturbine / Rotary Turbo
State of the Art Novel InFlow Tech GEARTURBINE Rotary Turbo Similar System of Aeolipile 10-70 AD
*1; Gearturbine Project, Rotary Turbo, Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD · With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses · 8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type.
gearturbine, imploturbocompressor, pdf.pdf
State of the Art Novel InFlowTech Project Development; ·1-Gearturbine RotaryTurbo Retrodynamic = Dextro RPM VS Levo InFlow + Ying Yang Way Power Type-Non Waste Looses, Similar Aeolipile System 10-70 AD, Pat197187IMPI MX Dic1991 / ·2-Imploturbocompressor One MovingPart System Excellent Design and One Compression Step to, Similar to Hurricane Satellite View, Same Implo inflow Way, from Macro to Micro
Adobe Portable Document Format - 1.90 MB - 04/25/2017 at 20:47
Preview
Carlos Barrera wrote 04/25/2017 at 20:48 • point
State of the Art - Novel InFlow Tech - Featured Project Development; |/ *1; Gearturbine Project, Rotary Turbo, Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD · With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses · 8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type. |/ *2; Imploturbocompressor; Implo-Ducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature.
