The teensy ps/2 keyboard library was extended to support notification of key releases.
I maintained backwards compatibility and added 2 new public methods :
add 'rel' to the usual method, and provide an iskeyrelease bool parameter.
this parameters is referenced and set to true when the keypress was a release..
Only a few keys are supported right now. I plan to refactor the code to eliminate redundancy and implement full playable keyboard.
So the code below shows a simple example of sounding a synth sound as long as key 'c' is pressed.
void loop() {
if (keyboard.availablerel()) {
// read the next key
bool iskeyrelease = false;
char c = keyboard.readrel(iskeyrelease);
KeyboardHandler(c,iskeyrelease);
#define _SYNTHPRESS_STATUSCODE 0x90
#define _SYNTHRELEASE_STATUSCODE 0x80
void KeyboardHandler(char key,bool iskeyrelease)
static bool c_pressed = false;
byte synthstatuscode;
byte volumecode;
synthstatuscode = iskeyrelease ? _SYNTHRELEASE_STATUSCODE : _SYNTHPRESS_STATUSCODE;
volumecode = iskeyrelease ? 0x00 : leadvolume;
if(key=='c')
if(!c_pressed || iskeyrelease)
midiwrite(synthstatuscode, 40, volumecode);
c_pressed = !iskeyrelease;
return;
