At last a project that went smoothly for a change. The MAX1238 chips arrived, and I soldered them to the PCBs and they seem to be working just fine at first sight. I was a bit worried about the chips being too small when I saw them, but they are fine.
I wrote a very simple MicroPython library to handle this shield:
class MAX123x:
def __init__(self, i2c, address=0x35):
self.i2c = i2c
self.address = address
self.reset()
def reset(self):
self.i2c.writeto(self.address, b'\x80')
def read(self, channel):
if not 0 <= channel <= 11:
raise ValueError()
data = self.i2c.readfrom_mem(self.address, 0x61 | (channel << 1), 2)
return ((data[0] & 0x0f) << 8) | data[1]
deʃhipu
"a project that went smoothly".... i think you are writing fiction now... "Shirely" you are joking.....
(nice work btw...)
Well, I'm sure there are problems that I'm not seeing that will manifest themselves down the road at some point, of course. I did it too many times already to really believe I got everything right at the first try. And of course preparing this for the semi-mass production required for Tindie is going to take some more work. But so far so good.
Thank you for your kind words.
