LED Box for Displays, Awards and Games
The 5x5 WS2812 LED box was built for the DARIAH-DE DH-Award. It has a button to switch modes and can be scaled / modified for games as well
The LED box is made from 3mm acrylic, with a front sheet of semi-transparent acrylic (WS10 / WS20). It is controlled by an Arduino Nano and contains a 5x5 LED matrix from WS2812 strips in the top part, a button to the left and an on-off switch. As a power source, we used a stripped usb cable that is connected to a standard mobile phone charger / powerbrick.
The front cover can be easily replaced. For the graphics on the front, we used a Plotter to cut out stickers (GCC Expert Pro).
Software: Arduino with the Fastled library, code for effects at
https://gist.github.com/mneuschaefer/50fe4537a589a2e698b32f7ae7423f14
This project was inspired by Raspberry Pi Retro Gaming LED Display: https://hackaday.io/project/11064-raspberry-pi-retro-gaming-led-display
(detailed logs follow)
Arduino drivers: http://kig.re/2014/12/31/how-to-use-arduino-nano-mini-pro-with-CH340G-on-mac-osx-yosemite.html
Portable Network Graphics (PNG) - 76.67 kB - 04/27/2017 at 10:57
Preview
LED box 3mm.svg
a single LED box
svg+xml - 128.43 kB - 04/27/2017 at 09:58
Preview
3 led boxes 3mm.DXF
for bulk production :-)
AutoCAD DXF - 366.93 kB - 04/27/2017 at 09:57
Download
aufkleber dariah.svg
svg+xml - 14.82 kB - 04/27/2017 at 09:57
Preview
aufkleber dariah dh award.svg
svg+xml - 20.15 kB - 04/27/2017 at 09:57
Preview
View all 6 files
