It all starts from an issue with our water boiler ...
In winter it's too cold on the first mode and too hot on the second mode.
In summer, way worse, it's too hot on the first mode ...
So i wanted to PID it with some PWM. The thing is that in Germany almost every house using this sort of on-demand-boiler has Triphase 480V so it has to be beefy!
Details
We just needed to replace the faucet... Problem solved !
Files
BoxBottomV3.STL
Standard Tesselated Geometry -
335.63 kB -
05/06/2017 at 23:58
