As asked, here is a link to the sketchup model of the concept as seen in the images, this version has not been tested yet, nor 3d printed. If someone would please try, add a spring from an existing mag and let me know how it fails (which I expect it to as this is literally version 0.1). The latch that prevents the bbs flying out also needs a spring, the hole should be adjusted large enough that a spring from a cheap click pen should work.
As mentioned in a previous post, college is taking my time away from working on this and without a 3d printer to test my ideas on, I'm pretty limited. If any airsofters with personal 3d printers would like to join this project as a contributor and help make this a reality, please message me.
I've also have a new design that I intend to create that will do away with needing a long feed spring as I've had difficulty trying to source those springs on their own. For now anyways, I'm still busy with college but hopefully someone will atleast try printing this current version.
TAIBHSE DESIGNS
Hey there. I am working on printing it. My sketchup skills are not great. Is it possible to get STL of each component separately? I got as far as opening he file in sketchup :P
