Outlet Guide Vane Rough Calculations
A project log for 3D Printed Axial Compressor
An axial compressor that is designed to be produced inexpensively by the daily hobbyist
noobsaucenoob_sauce 05/22/2017 at 14:010 Comments
Anyways, here are my caluclations:
In addition to those angles, like stated before, I also plan on doing a deviated blade, one that has a different angle of attack at around 1/3 of the length. This angle will be around 45 degrees.
So because of all these weird angles - if you can imagine a stage with an inlet angle of 22 and out of -45, I have to re-write my blade construction program. Also note, because this isn't considered a "working stage" it doesn't have the three stage variables:
I'll update this once I've re-written the program and have a 3D model to show you all.
Until next time.
Rich text editor
