The PCBs for the PewPew Lite arrived from @oshpark, so I assembled one and I'm really happy with it:
I didn't have an SMD diode at hand, so I just put a THT one there, and connected it to the correct pin (there was a mistake in the PCB, if you remember the previous log). I also quickly extended my HT16K33 drivers with a class for this board:
class PewPewLite(Matrix8x8x2):
def _copy_buf(self):
pixel = self.framebuffer.pixel
_buffer = self._buffer
for y in range(8):
b = 0
for x in range(8):
color = pixel(y, x)
if color & 0x01:
b |= 0x01 << x
if color & 0x02:
b |= 0x01 << (15 - x)
_buffer[14 - y * 2] = b & 0xff
_buffer[15 - y * 2] = (b >> 8) & 0xff
def keys(self):
return int.from_bytes(self.i2c.readfrom_mem(self.address, 0x40, 2),
'little') >> 5
Nothing too fancy, just had to adjust the rotation and add a method for reading the keys.
I also received the PCB for #Ye Olde Nowt with the THT buttons, and now I'm thinking about how to use those buttons also with this project, as they are much more compact. Probably won't work, since I really need stuff on both sides of the PCB. There is one more type of buttons that I might try -- they are SMD, but use pads under the buttons, and not legs, like the ones here.
And of course I *really* need to start writing the games for this. I already have ideas of a dozen of them.
