If you have a 3D printer or other possibility to fabricate a plastic casing - we have a good news for you! We’ve designed simple enclosures for our different board configurations:
- CORE2 only
- CORE2-ROS (the top cover is the same, but the bottom cover is extended to cater for the BC size)
- CORE2 with CORE2brick shield (the bottom cover is the same as for CORE2, but the top cover is extended to cater for the shield size)
- CORE2-ROS with CORE2brick (top & bottom covers are extended)
Enclosures are open source and available on our GitHub: https://github.com/husarion/CAD-Models
Husarion
