I'm not sure how useful it'll be to you all, but I'm cleaning up and commenting my code before I post.
I'm using the Arduino Core for the ESP32 and the standard signal names for these ePaper displays - so even though the boards aren't working, maybe you can borrow my timings or look at how I'm driving the screen. As I promised, I'll spin up another board - but since I have two more days and an ESP32 I'll be working mainly on Internet features this weekend.
Also, I'm adding greyscale support to the display, using a similar method to NekoCal's. I use progressively greater number of refresh cycles to change the brightness of an area. I'm experimenting with 16-grays or 4-bit color and it doesn't look so bad right now.
Once I lock that in I'll post.
Here are my current timings so you'll know if I made progress when the code goes up:
4 output cycles coming!
// The next one is a clearscreen
Took 1327 ms to redraw the screen.
Did anything happen? Adding one and trying again.
// The next one is drawing a picture.
Took 6351 ms to redraw the screen.
And what am I drawing in those 6.3 seconds? E-Paperception, of course!
Okay, more soon - and more speed. Stay tuned.
