Found that a thick wire can be used to drill throug the bamboo, from 2 sides.
Works ok. If the wire is to thin, it may break and be stuck in the bamboo. Yea, haz variable drill-length! :)
A project log for Autonomous liquid growing Algae environment
Goal is: Producing solid/liquid fuel from algae. The system consists of a algae-water loop and a processing setup.
