I am now able to commit messages to Github using their API.
pygit was overkill and I can do everything using requests/json with the API. Here is the code before it has been converted to micropython:
# coding=utf-8
Writing this code in regular python before moving to micropython.
This code will handle putting commits up on Github for the Github connected Soldering Iron
import json
import requests
GITHUB_OAUTH_TOKEN = "your_oauth_token_goes_here"
GITHUB_REPO_ADDRESS = "" # For example: "Cabalist/testSolder"
commit_message = "First try #2"
last_commit = requests.get("https://api.github.com/repos/{}/git/refs/heads/master".format(GITHUB_REPO_ADDRESS),
params={"access_token": GITHUB_OAUTH_TOKEN})
last_commit_sha = last_commit.json()['object']['sha']
r = requests.post("https://api.github.com/repos/{}/git/commits".format(GITHUB_REPO_ADDRESS),
params={"access_token": GITHUB_OAUTH_TOKEN},
json={"message": commit_message,
"parents": [last_commit_sha],
"tree": "4b825dc642cb6eb9a060e54bf8d69288fbee4904"}) # This is the empty folder SHA in git
commit_sha = r.json()['sha']
r2 = requests.patch("https://api.github.com/repos/{}/git/refs/heads/master".format(GITHUB_REPO_ADDRESS),
headers={'content-type': 'application/json'},
data=json.dumps({"sha": commit_sha, "force": True}))
cabalist
