So I read a bit into current to voltage circuits and seems the resistor
only approach is pretty bad. Using an op-amp as a virtual ground seems
to produce quite a lot better results, those guys are super cheap so
that doesn't add much/anything at all to the bom.
I will pick one up tomorrow and see how that goes.
