- Size: about 50x50mm (size of condoms I have, could be a little larger if required)
- Layers: preferrably a single 2-layer PCB, for easier ordering at the usual suspects in China
- Connections:
- debug UART
- MicroUSB for charging the battery
- temperature sensor connector
- two Neopixel strip connectors (without VCC, only DATA+GND)
- battery connector
Components:
- ESP-12, no doubts
- Some kind of ADC setup to measure the
- EPIC - with some space around to apply gunpowder on top of it
- One WS2812 on the board
- Battery charger IC
- Vibromotor
- Microphone - using I2S, like this one
- I2S DAC for the tweeter (what the hell, we have a tweeter? I guess that's happens when project contributors edit the description =D )
Something else? I need ideas, I'll draw the first board as soon as I'll have some free time.
Arya
