I moved component into a new version of the 3d case, printed last week.
I moved the USB charging circuit to top right (so you can play while charging) and added 2 more screws holding the bottom of the case and 1 on the top of the case.
It works but there is an issue with sound : left and right channel are kind of mixed, so it’s not really stereo.
